1994 Bayliner Capri 1850 LS restore
RollTide13
*** I changed the title of the thread since I've moved from a few fixes to a restore (step #1 denial) ***
I'm thinking about fabricating a new motor cover for my 1994 Bayliner Capri.
I'm sure guys have done this before. I did search through the archives and couldn't find an example (walkthough).
The frame won't be a problem, but the current cover has curved corners, and I was wondering if anyone had experience curving plywood or if there was another material that you would recommend.
Thx!
Re: Rounded corner help for a motor cover?
Ayuh,.... Fiberglass,..??
jspano
if your looking for a material to use as a mold to form some glass around, i have seen a product that looks like peg board without the holes that's bendable to an extent. if you take some thin plywood and cut it to width and keep it 8 ft length you can bend it gradually and do it to 2 pcs and then cut and put them together. i know we use to bend drywall to cover arches by weting a 8 foot pc cut to width and placing on saw horses to allow them to bend overnight.
RollTide13
Thanks guys.
Sorry if the questions seem elementary, I have no experience in any of this - just learning as I go.
jspano
heck, i'm new to all this too! i just try to think outside the box. doesn't make me wrong or right... just thinking out loud
when people say you can't do that it just makes me want to do it even more
good luck
thrillhouse700
You prob already did this but take the old one apart and see how its made?
BobsGlasstream
RollTide13,
You could always use the old one as a model to build the new one if you liked the way it looked.
Just use a release agent (mold release) and then apply gel coat, fiberglass on the gel coat and then separate the two and use the layup for your mold for the new one. There's a little more to it but that's the basic idea.
Bob
RollTide13
Well I 'assumed' I would need to round some plywood. foam, etc. But it turns out that there were already curved plastic pieces in the original construction.
Here are some pictures of the new motor cover (the quality isn't the best - I used my cell phone).
Let me know what you think. I'll post pictures of the old cover and its condition when I get home.
Thx
New cover with treated plywood.
New cover with treated plywood from the back. Notice the plastic corner pieces.
Some paint to clean it up.
Foam in place.
Finished cover - front.
Finished cover - side
scipper77
That is some of the best non professional work I have seen! Nice job.
Robert4Winns
Very nice work!
Squid Billy
Very Nice Job!!!!!
A simple way to get shapes that are rounded or contoured in flowing shapes, is to use foam. It doesn't really matter what kind, but for myself, ... I prefer the blue foam as it is dirt cheap and shapes extremely well and as Bond-o said; "Fiberglass?"
All that is needed is an imagination, sand paper and EPOXY "only" if you use a styrene based foam (white, blue, pink). If you use the Urethane foam, usually amber in color but comes in other colors if it's in sheet form, then you can use either polyester, viynlester "OR" epoxy.
BobsGlasstream
RollTide13,
i can't find anything wrong with what you did.
Very nice work.
Should last a long time as long as it is sealed good.
Bob
RollTide13
Thanks for all the comments guys.
I'm pretty happy with how it turned out. It could be better, but it's the first time I've ever upholstered anything.
Of course now that I've done one piece in the boat, I'm going to have t redo the rest of the interior. I'm sure you guys can understand! LOL
Here are a few pictures of what it used to be for comparison.
Old cover - front view
Old cover - back view
The vinyl is off. It was all I could do to keep it standing up without crumbling!
Mark42
Good decision going with treated ply. Will last a long time. Really nice job. Looks factory!
RollTide13
Re: 1994 Bayliner Capri 1850 LS restore
Ok, I've changed the name of my initial thread from questions about rebuilding the lower motor cover to a restore thread. I guess I've passed the denial phase..lol
The boat sat uncovered for at least a year. All the cushions are cracked and water logged. The engine runs but needs a new head gasket and trim adjustment according to the PO (we will see). The floor feels pretty solid but if the rest of the boat is any indication, it will need to be replaced. I'm just hoping to use it this summer and do the 'big' work next winter.
So here is what I'm planning on and my 'tentative schedule':
Phase 1 (Pre-Summer):
1) replace all cracked and ruined upholstery
2) replace all rotted wood in side panels, seats, bolsters, ski locker cover with treated ply and oil based paint
3) have engine evaluated and fixed (not an engine guy so I'll pay for this)
4) have all electrical systems evaluated and fixed
5) restore yellowed and oxydized fiberglass
6) replace tires on trailer
7) use boat this summer
Phase 2: (Next Winter)
1) Replace floor, carpet, stringers
2) strip and repaint hull
3) strip and restore trailer
What do you guys think. Does it make sense?
ezmobee
I'd get the motor/drive checked out and made fully operational before I spent a DIME on anything else. After that though, I see no issue with your plan. Just be careful with all the work you do this season to make sure it is able to be easily removed (without damage) next winter when you tear it apart again to do the floor.
RollTide13
I'm doing the upholstery myself (I'll post pictures soon). I've recovered most of the seat cushions and now I'm moving on the the bow bolsters, trim and side panels.
Last night I removed the bow bolsters. There were three screws accessible through the dash panel. After that there were two metal clips that attached to holes in the wood backing. The only problem I had is that there was another screw further down. The wood was soft so it just pulled out, but now I don't know what I'm going to do to replace that screw.
There is no way I could have reached it unless I popped the cap off. I was thinking that maybe one of those plastic fasteners used in cars might work. I just don't know. The other funny thing is that the screw on the other bolster was in a completely different place.
Any ideas?
Bolster removed
Close up
RollTide13
I agree with you EZ. I've already called around and priced a full rebuild or used replacement and worst case is about $2000 installed. We've decided to keep the boat for awhile so I'm fine with that.
Also, I figured that restoring the interior should help with resale whenever the time comes. I only paid $575 for the boat and trailer combined and have probably put another $300 in it with vinyl, wood, radio and speakers.
lgrouper03
rolltide,
I have a 93 1850 Capri and at some point would like to re-do the seats, etc. Maybe next year, because right now I am in the teardown stage for stringers and transom (just got past the denial stage about a week ago). Anyway, I'm very comfortable working on engines and fairly comfortable with this project I'm diving into right now. But when it comes to upholstery I have no idea. Are there any secrets to it, or is it mostly initiative with some wise judgement?
Thanks, lgrouper
