1994 force 90hp lower mount
Robs88
Hey guys need to find a lower motor mount for my 90hp force mine went bad, does anyone know where to order one from, Also does anyone have detail instructions on how to reinstall the new mount on thanks...
Re: 1994 force 90hp lower mount
Lower motor mount?
On the midsection?
Go here
http://www.boats.net/parts/search/M... THRU 0E093699/DRIVESHAFT HOUSING/parts.html#
Zoom in on the sketch and id the part you need.
You can order it from any Mercury dealer, or from several online dealers.
If its a different part you need, go here and look up the correct part.
http://www.mercruiserparts.com/selectDocs.asp?doc_nbr=823424
Detailed instructions are best in the Clymer Force repair manual, or a factory manual.
