1994 Force by Mecury Water Leak
2000vikings
I have a 1994 Force 70hp that is running great, but recently I noticed that I have water leaking from the middle of the motor at the bottom of the motor case. It seems like it only sprays out when I am running the motor at higher speed. It does spray water normally out of the hose and hole. It doesn't seem to impact performance but I don't believe it is normal. Any help is appreciated. Thanks.
Re: 1994 Force by Mecury Water Leak
Normal on all I have seen.
As long as you are cooling, then this is just water built up in the leg that hasn't gone out the prop hub yet.
Hey - your supposed to be holding on to the steering wheel while driving a boat, not hanging over the transom looking at the motor!!! :)
2000vikings
That is great news, thanks for the information. Yah, my neck gets pretty sore trying to hold the wheel and look behind me at the same time. :)
