1994 mariner
papamike
want to do a compression check but cant find the specs, anyone know upper and lower limits please. thankyou
Specs are not usually given on OBs. You want compression numbers to be ever across all cylinders, and at least 100PSI. 15% deviation between cylinders is acceptable.
