1994 mercury 225 black max
fishmaster2
bought a used crestliner W/A cuddy with this motor --threw a few thousand at it and it runs great (mostly) -- likes to stall at low speed when docking though---my wrench says do not touch the red button on throttle when going from forward to reverse---then when going back to forward thats when it stalls---frustrating---any thoughts
anyone know how I could get the black max emblem ( the guy with the beard)in a .jpg or a pdf ---childish I know but I want it
Staying alive
Faztbullet
Re: 1994 mercury 225 black max
Is this a carb or EFI engine? Has the shift switch been tested?
ufm82
Where is the idle set at?
Faztbullet
Depends on what engine you have..... A EFI is 650+/-50rpm in gear and a carb model is 750+/- 50rpm in gear.
fishmaster2
it is a carbed model and my merc mechanic says the shift switch tested ok ---but i question it ----I can run all day no problem then when idiling into dock ---shift from forward to reverse it stalls ---big problem
sschefer
Fatzbullet, doesn't that motor have the idle stabilizer on it. If it has it and it's bad you might experience this problem.
Faztbullet
Faztbullet, doesn't that motor have the idle stabilizer on it.
Yes it has a idle stablizer but it is built into the ECM...and yes the carb models have a ECM. You could have a bad shift diode replacement # 17461A5
fishmaster2
Thanks for the info Faztbullet---and sschefer----------- will check into the shift diode right away ----want to get this thing running right it goes fast and strong when I got her out on the water --- but when you play bumper cars when docking its embarrasing
Fishmaster
94 Crestliner 236 Eagle W/ 225 Blackmax
fishmaster2
sorry guys I may have given bad info ---it may be a 1993 ----don't know if that makes a difference in your answer
Its a Mercury 225HP offshore 3.0L ---------SN: 0G089101------It is very hard trying to find the year
Fishmaster2
