1995 Yamaha 115 prop shaft replacement,
healey8390
Can I use a long jaw puller to get the carrier/spool out. I can't find any specific videos for the year. Is the prop shaft pressed into the spool? Thanks.
Yes , use a puller to get carrier out.----There are no " press fit " parts to do with the propshaft.
healey8390
I got the carrier out but the bearing on the back of it stayed in along with the prop shaft and reverse gear, they won't pull out. Any suggestions? Thanks.
