1996 15 hp johnson lower unit
danintruder
i have a 1996 15hp johnson kiker motor that runs good but i may need to change to a longer lower unit so that it clears the hull more .here is a photo of the plate on the motor .what am i looking for to find a compatible used motor to get the lower unit from serial no ? year ? hp? sorry the photo is upside down ! don't know what happened!
They are not all exactly the same internally.-------But a 74 to 2007 lower unit will bolt right up....----Note, try to find one from 1993 to 2007 as they are a wee bit more robust with 2 pinion bearings.
