1996 E50TLEDS Evinrude 50 HP 2 stroke
wjk
There is a 1" brass nipple that sticks out of the center of the front of the powerhead that is dripping fuel. Can anybody educate me on this. I looked in my SELOC Johnson/Evinrude 1990-01 Repair Manual and found nothing pertaining.
Is it on the intake manifold? Top middle bottom?
Try looking on parts page and see if you can find it there.
Describe this " nipple "----Or is it the pulse limiter.----Running with VRO or pump mounted to the side of top cylinder ?
wjk
It looks like there should be a hose on it but there isn't. Running VRO
Should be a hose going from it to a nipple near bottom of airbox.-----Why would you do a VRO swap and primer solenoid rebuild?
wjk
The VRO was leaking from the top and the primer solenoid top was cracked.
