1996 Force 120hp power head removal
ErichDahlem
Removed the 8 nuts off the bottom, the 4 bolts from the inside all wires and hoses and cant remove power head. Anyone have any idea why? Thanks in advance Erich
jerryjerry05
Re: 1996 Force 120hp power head removal
If U'r sure that all the bolts are loose.Then U might have to pry it apart.They use silicone and it can get pretty sticky.J
DDavis6384
I too am having problems removing my powerhead. I also have a Mercury Force 120HP - 1996 version.
I have a repair manual that says to remove the exhaust housing and remove the 6 nuts that are exposed. I had 8.
Then, remove the 3 bolts on each side of the front of the block holding the spacer plate. I have no bolts that I can find. I did remove 4 bolts that mounted to rubber shock mounts in the bottom of the engine housing.
I (and my powerhead) are stuck! What do I do now? :confused:
Doug
droach77
Wiggle it and it will come off, just watch the shifter mechanism they are sorta a pain to get repositioned. I thought mine was unhooked and it ended coming off with the motor, note the position its in incase it moves on ya. good luck
dave
Racewerx
They do stick I had to pull and twist to get mine off.
64BOOMER
I was able to remove it after some help. Takes two a little heavy. thanks
hypersniper
Banned
i have to do a piston on my merc/force sportjet 90 and hopefully wont have the same problems. i will just break out the B.F.H. aka big freekin hammer... lol.. just kidding.
