1996 Johnson 130 "Check Engine Light"
gregr1971
this boat has the system check Tach, when ignition is turned on, all 4 lights come on, then go off, and the "check engine" light comes back on, and stays on.
It runs perfectly fine.
Any idea where to start the diagnosis??
Re: 1996 Johnson 130 "Check Engine Light"
The "Check Engine" alarm is a restriction in the gasoline supply to the motor. It is set off by a vacuum sensor next to the OMS pump. However, your motor is a V4 right? I do not think they were equipped with that sensor in 1996. In that case, the sensor wire is shorting to ground. Look for some missing insulation or chafe. The wire will be tan with a trace color, and should be near the OMS pump.
Faztbullet
If I remember correctly it will be in a 6 or 8 pin connector and color will be tan with orange trace.
gregr1971
Ok, I do not have the fuel restriction
vacum swith, so where exactly does the
wire go? Is it just dead ended into the
8 pin connector?
ezeke
Pin 8 is for the horn, pin 7 is for the check engine light.
"Pin 8, used to activate the warning horn, supplies a ground to the horn circuit when any other warning circuit (pins 4 thru 7) is grounded"
1234
8765
gregr1971
Ok, checked all connection, checked for
chaffing, none found. I totally removed the
tan/orange wire, and pin from the connector
at the tach.
Light is still on.
gregr1971
pin # 7 is the one I completley removed from the deutze connector at the tach. I am thinking I have a circuit failure in the tach itself.
gregr1971
And yes, it is the 130 v4 looper (I love this engine!!!)
hieu nguyen
i don't know too much on your engine, but i have 2000 injection motor,they this live your motor, check engine light on all time, i check on my motor, they have 1 coil come out spark low votage, i change that coil now my engine run five no arlm and no more check engine light come on. that all i know. and good luck to you.
seahorse5
Because the electronics to turn on the various warning lights are built inside the gauge, then most likely the gauge is faulty. This assumes that there isn't a short in the sensor wiring.
gregr1971
New guage fixed the problem.
Thanks
