Chuck4741444
- Joined
- Jun 6, 2020
- Messages
- 145
Motor new to me, it running rough, I have rebuild carbs, clean the holes in the throttle plate, stars and runs easy. I have sprayed carb cleaner on the carbs, throttle plate and the intake manifold.
Crank case seal, check for loss fuel lines, I cant find an air leak, I pulled the plugs and they ate all wet, could this be a bad coils ? 1 or more?
