- Joined
- Jul 18, 2011
- Messages
- 19,170
Re: 1996 mercruiser 5.7 with thunderbolt ignition ... Top End knock Please Help
I think that is excellent pricing for all the stuff that was done. Let's hope that the engine does you well for a long time.
Well everything is back together and I'm going to get the boat tonight as long as it passes the mechanics water test. Ended up putting a new starter on it as well since the old one was hanging up a bit. total work done
pull and replace motor ... $600
Other labor .... $600
4 barrel carb, high rise intake, circulation pump ... $200
Cam and lifters ... $150
Starter ... $200
Gaskets ect ... $250ish
extra prop ... $30
Exhaust butterflies ... $200
Head work $350
Outdrive parts ... $250
Drain plug hose kit (will be nice to get everything out) ... $50
After everything is said and done im into the drivetrain for about $3000 just in case any of you were wondering
