1997 9.9 Impeller Change
markdido
I have the parts, waiting for the manual.
Any tips / tricks / words of wisdom that might not be in the service manual?
Re: 1997 9.9 Impeller Change
Here are some tips
Nothing gets forced. Do not use the bigger hammer mentality or bull your way through it.
When you remove the old impeller make a diagram of which way the fins are ........install the new impeller the same way AND lightly coat the impeller with some vaseline and it will help the assembly since it sits in the housing offset.
A tiny dab of never sieze on your bolts will not hurt at all.
