1997 johnson 200 h.p.oceanrunner j200txeua
Phil100
No spark on the 3 starboard side cylinders. The 3 port side have spark. any reason? what should I be going after
jakedaawg
Re: 1997 johnson 200 h.p.oceanrunner j200txeua
If all electrical connections are good then you lost a power pack.
That motor has a single powerpack. Check to make sure the Shift Assist (starboard side on shift linkage) switch is closed. This kills spark to 1/2 the motor when you shift in/out of gear. Disconnect the SLOW sensor wire at the powerpack, as this system kills spark to 1/2 the motor when it detects overheat. There is blocking diode that can cause incorrect operation of SLOW, as well.
Phil100
Thank you for your feed back. I disconnected the black/yellow wire going to the shift interuptor switch and now I am getting spark to the starboard side. will be replacing this switch.
Phil100
I disconnected the black/yellow wire going to the interuptor switch and now I am getting spark. Thanks for your input. I will replacing switch.
daselbee
Should read: Check to make sure the Shift Assist (starboard side on shift linkage) switch is OPEN.
The switch closes momentarily when shifting, killing the three stbd cylinders for a split second to reduce strain on the LU.
