I have a 1997 Merc 5.7LX with Tbolt V and the knock sensor. I have been chasing a WOT issue since I have had the boat (6 years). The boat basically will hit 4000-4300 rpm's regardless of prop pitch. I am running a 17 pitch now. This is a 22 ft. bowrider.
I have always suspected timing. The boat has decent acceleration and will pull a skier, but I think there is more to be had.
So I tested the Knock module/sensor by hooking my dvm to the purple wire and ground. I believe it is supposed to deliver 8-10 volts. I get 4.5 at idle and it jumps around. At 2000 rpm, it sometimes hits 8v, but most of the time it is under that.
I checked the timing and at 2000rpm's I am getting 24d of total advance. Looking at the Merc SB's this should be up around 35-40d (if I am reading correctly). It seems like the knock module is retarding the timing. This is also the case if I unplug the knock sensor.
Before I replace the knock module, I am curious if it could be something else. I would think the module would work or not - the erratic behaviour is confusing.
