1997 mercury 90 hp 3 cylinder popping noise out exhaust
Little Richard
I'm wanting to buy this boat for 3000. He started it on muffs and it idled a little rough. He reved it up a little and when he stopped it gave out a couple of pops. I'm going to check compression, spark, timing and lower unit for water. He said he has never cleaned the carbs and says it runs like a scalded monkey. Also says it doesn't do that on the water. So what y'all think? Dirty carb or slow idle mixture screw needs adjusted
flyingscott
Those pops are normal when on muffs so is the idle being rougher. Take it for a test drive
