1998 Johnson Venom 200hp decals.
sstumpf
I am looking for a decal set for the 1998 Johnson venom 200hp but I am having trouble finding anything. I would like the original decals. Is this possible, or what is a good alternative. Help is much appreciated, thanks.
OutOfControl
Re: 1998 Johnson Venom 200hp decals.
sstumpf,
If you have the SJ200WTPLG or SJ200WTPXG model the OEM decal kit is available thru BRP's web-site.
Hope this helps.
sstumpf
Well I have the J200stlece, but I wonder if the decals are close enough to wear they would fit and look fine. You think they would because it is from the same year.
OutOfControl
sstumpf,
The BRP web-site shows "not available" for your model.
If you have an OceanRunner they are fairly generic in terms of decals, just with different HP #'s on the back panel.
I am sure decals can be made to order via a third party, not sure about copywrite violations. We have a small vendor at a local flea market that will print just about anything you bring them or design yourself.
Let us know if you find a source on-line.
A google search turned up several sources including this one. dub-dub-dub outboarddecals dot com
sstumpf
not they do not have the oem original decals, just decals that simply say johnson.
Sixmark
If BRP says not available, then take your hood down to your local vinyl shop and have them repop the decals for you. if you bring them the hood they can get all measurements, angles spot on.
sstumpf
ya I think I will have to take it to a vinyl shop. I have a guy that I know that has one, so I will probably just to that.
sstumpf
I think I could just go with something like a Johnson on each side, then a 200 on the back. Where could I get a decal big enough for my motor.
