1998 Mercury 150 loosing gas line primer bulb pressure
Joseignacio
I have a 1998 Offshore Mercury 150. The outboard lost power and the primer buld was not hard. On one accasion, the engine almost turned off but I primed the line again making the primer bulb hard and the engine came back alive. It was as if the line is loosing pressure. The problem happened about three consecutive times and then it did not happen again. I am afraid something is about to happen ...........
j_martin
Re: 1998 Mercury 150 loosing gas line primer bulb pressure
What's about to happen is burning down the power head. They do not like to run lean. They get too hot and the pistons melt.
It's normal for the primer bulb to not be real hard when it's running. After all, you are sucking fuel through it with the fuel pump in the engine.
Either the fuel pump is failing, or a fuel filter is plugging, or there is a restriction or air leak somewhere.
hope it helps
John
Really Old Guy
10 year old gas line, needs replacing. It could be an air leak.
Those zip ties should be replaced with stainless hose clamps
and check your fuel lines in the carb area. while putting gentle
pressure on the bulb.
Hope you find it soon!
Guy:)
"G"
You might check the in line fuel check valve (usually found on top of the tank) too. If that isn't doing it's job you'll loose suction. It's the same as an air leak so look for both. Gas line parts are cheap compared to powerheads.
Dukedog
All of the above and rebuild your pulse fuel pump. Its cheap and you will have all tha fuel issues covered (at least ta tha carbs and/or efi).
j_martin
A sleeper here. If the pulse hose has gotten soft, or leaking, the pump will be weak.
Ask me how I know. (Tygon hose)
John
hkeiner
In my opinion, systematic diagnosis is a good way to go. As previously mentioned, fuel starvation is not something you want to delay solving. Randomly trying various possible fixes on only a hunch can delay solving the problem.
The below linked troubleshooting guide may help you find the exact problem quickly. Alternatively, hooking up a portable fuel tank directly to the fuel pump, to see if the problem goes away, is another way to narrow down the problem. If the problem does not go away with the portable tank, the fuel pump is most suspect. If the problem does go away, a fuel line restriction or air leak is suspect.
http://forums.iboats.com/attachment.php?attachmentid=26607&d=1240244928
http://forums.iboats.com/attachment.php?attachmentid=26608&d=1240244937
http://forums.iboats.com/attachment.php?attachmentid=26609&d=1240244945
http://forums.iboats.com/attachment.php?attachmentid=26610&d=1240245079
j_martin
When I shot a similar problem out of my XR4, I wound up hooking up a fuel pressure gauge. When the symptoms occurred, the gauge would go way low to near 0 psi. 2 lbs seemed to run it fine. (carbs, of course)
There were 6 or more seperate items all contributing to the poor fuel delivery. I knew it for sure when I found them all.
hope it helps
John
emckelvy
All excellent comments. I did several this past year where ethanol-bearing fuels were a major contributor.
Merc has issued several TSB's on fuel starvation, with some of the problems due to deterioration from ethanol-fuels, but from other issues also.
Here's a link to the .pdf file for the current (as far as I know) fuel starvation TSB:
http://dc151.4shared.com/download/101684956/9767ea93/2001-17_Fuel_Starvation.pdf
HTH & G'luck with the troubleshooting.........ed
