1999/2004 3.0 liter opti powerheads
naz14
Does anyone know if a 1999 200hp 3.0 liter Optimax power head can be seamlessly replaced with a 2004 3.0 liter optimax powerhead? Will the accessories on the 1999 Opti, such as the compressor, the fuel vapor separator, the fuel injectors, etc., bolt on to a 2004 3.0 liter Opti powerhead, or are the different year engine blocks set up differently for their respective accessories?
Faztbullet
Re: 1999/2004 3.0 liter opti powerheads
They are set up different. 98 is all to itself as is 99 and 2000. 2001-02 will interchange with each other ,2003-06 will swap with each other
naz14
Thanks for the input. I knew that the different years were set up different with new updates and and accessories ie; air compressor, fuel rails, fuel pumps, igectors,etc. but I was hoping the bare powerheads were the same and would allow the assembly of the earlier model accessories.
