1999 gen II outdrive 4.3 merc
netting one
Boat just stopped moving last year! Pulled top plate off of outdrive and gears were gone! (low oil ) buddy thought he would change it himself and only put a 1/4 qt in from the top! My question is every one i talk to says need a new outdrive its junk, dont bother putting gears in it buy new! The boat only has 134 hrs on it? Why not put new gears in?
Re: 1989 gen II outdrive 4.3 merc
Nothing wrong with putting new gears in it but the worn gear pieces wound up down below crunching up against all the other gears, bearings and such. If your going to try, then need to pull the entire drive apart and go completely through it. More then likely it will cost less to get a new Gen II SEI outdrive for 1500 with 2-year warranty
Alpha One? Gen II Sterndrive Applications | sterndrive.cc
^^ +1
the cost to rebuild what you have will most likely be more than a new drive
on another note, its a 25 year old drive with only 143 hours that is less than 6 hours per year. that is about 2 outings a year. I would question the hour meter
thumpar
Are you sure you have a gen II? Gen II didn't come out until 1991.
netting one
Thats what ive been told that the labor and parts are more then a rebuilt one. The boat was his uncles and never used it, and its a 99 my mistake. thanks for the help looks like its time for a rebuild.
Ayuh,.... The Parts, Alone, without the Labor will be more money than buyin' a brand new SEI from iboats,....
'n the SEI comes with a 3 year, no questions asked warranty,..
