2 + 2 Mercury 125hp
leander borg
Do you have any ideas on how to eliminate the 2+2 so that the engine would work on all 4s all the time?
Faztbullet
Re: 2 + 2 Mercury 125hp
Wont run/idle worth a crap on low end, been tried and no successes. If its set up correctly and everything working properly you would not know or notice the transition unless someone told you it worked that way..
CharlieB
