2 sonars off the same transducer
89retta
I've got a hummingbird helix 5 on our boat . It's mounted on the port side. What I would like to know is if I got another smaller hummingbird sonar can I run both units off the same transducer? Thanks for any help
Assuming both units would support the same transducer, (power and frequency) you would need a way to switch the cable from one unit to the other, I.e. selector switch.
Assuming both units support a NMEA 2000 interface, you could network the two units together and “share” the transducer signal
