20 hp merc shaft conversion ?
HookMaster
I have a 2000 20hp tiller OB 15" shaft....... Need to make it a 20" shaft..........Any help ?
Re: 20 hp merc shaft conversion ?
2 ways to do this ---Find a long shaft driveshaft.---Find a long exhaust housing.---Find a long water tube.---Find a long shift rod.-----Then take lower unit apart to install driveshaft.-----Take powerhead off to install long exhaust housing.-----------------OR See if ----Bay manufacturing has an extension kit for you.----Much easier to install.
HookMaster
Thanks... Yes Bay has a kit.....$420.00 retail.
I would want the whole motor for that kind of coin.---Donor motor with a blown powerhead is a good way to do this.----It will take time and patience to find one.-A lot depends on your local as well.
oldman570
The easiest way to switch to a long shaft motor is to just buy one and sell the short shaft. Good long shaft motors can be found and it could be the cheaper way to go in the long run. Or as racer states find a long shaft motor with a bad power head and buy it complet and change the power heads around. Ether way it will cost $$$ ,but the work involved will be less in the long run. JMO
Oldman570
HookMaster
This short shaft I have probably has only around a hundred hours on it. Not sure I could find a used long shaft in the same condition.... I'll look around.... What's the short shaft worth if I try to sell it ?
carholme
Best prices I can find:
P/N 9098T5 D/S Housing:
Used Mercury 25 XD Serial 6577777 Driveshaft Housing 20" Long 9098T5 | eBay
86292 Water tube:
1982 Mercury 18HP Water Tube Long P N 86292 | eBay
99198 Drive shaft:
Mercury 20" Driveshaft 99198 Fits 1984 2006 18 20 25 HP 2 Stroke Item 16404 | eBay
862933 Shift shaft:
http://www.**************************/userportal/show_product.do?pid=89924
Comes to about $290.00 unless you can bid them lower but that is without shipping.
Gerry
Georgesalmon
no chance you can just cut down your transom?
