20 to 25 hp
cc67
So there is a guy advertising a 20 hp Johnson saying it is now a 25 hp just by changing the high speed jet from an .068 to a .072. Is that all it takes? I know the CI is the same.
I my eyes more fuel without more air just means you burn more fuel.
Is this a 1968 model ?----1988 ?---1998 ?-----Post the model # or pictures.
To turn that 20 into a 25 requires different Pistons, Cylinder Head, Intake Manifold, Reed Assembly, Carb, and even the Crankshaft(the 25hp version, is more precise in Balance)
To make the extra 5 hp from the same Displacement, OMC had to spin the engine several hundred Rpms faster. To do that, they had to change the Port Timing. To do that without moving the Ports in the Block, they relocated the Wrist Pin in the piston in relation to the Crown of the Piston, which effectively changes the Port Timing in relation to the Crankshaft. Doing so resulted in the piston not travelling as far up in the Bore, and that lowered compression, so a different Cylinder Head was needed.(a few Geniuses, have tried putting the 25hp head on the 18/20 engines, without changing the pistons. That results in serious detonation, from too much compression). To get the extra revs, the engine needs to be able to inhale better, so a bigger Carb and some mods to the reeds are needed..
Well---" hope is eternal "---Is what they say.----So now you know that the snake oil sellers are everywhere.-----Love seeing the junk off brand motors listed as " made by Johnson " or made by " Mercury "------So find the 20 HP jet and put it in.-----Will save you some beer tokens on fuel.
You must mean the Dreamers who think a 'Force by Mercury' is a Merc. Those are forever appearing in the Merc Forums
