2000 115 Ficht fuel injector question
rfiglia
I have a 2000 115 Ficht. model #E115FSLSSH 478 hours on her. # 2 cylinder fuel injector is stuck open. I have the evinrude evag and cable. Can I buy a used fuel injector rather then get mine rebuilt or buy a new one? How do I go about using the software in all 3 options I have.. Thanks..
Faztbullet
Send yours off and have repaired as you wont know if used one is any good.Also check and see it pintle tiphas broken as if so the cylinder can be damaged
rfiglia
there is no one trustworthy that I know of that can rebuild them.. Please don't tell me DFI technologies cause I already had problems with them...
A new injector would need to be " matched up " with the ECU and a used injector would need to be " matched up " as well.------This stuff is not " plug and play " by any means.
Faztbullet
Try below as spin off of DFI......
Marine Computer Supply
206 Congress Street Unit 1
Mobile, AL 36603
1-844-MCS-CALL (1-844-627-2255)
I will look and see if I a 2000 SS injector.....
