2000 70hp Johnson Fuel Pump
halibutts
If I am to switch out the VRO fuel pump to a premix situation what fuel pump would I need?
In the mid 1990's they offered a 3 cylinder commercial 65 hp model.------Same motor as yours !------just order that fuel pump and install it.-----Or block off the oil side on your VRO pump and use it to pump mixed fuel.----Your choice.
????--Find that on ---shop.evinrude,com----Easy as just a few clicks away.
halibutts
not that easy sir, as years and options differ. ....I mean wtf? mid 90's 3 cylinder commercial 65 hp model.????
??????----Then try a pump for an 83 model 70 hp
