2000 Bravo 3 grease color
87Aggie
Boat is new to me and am wanting to pull the drive and grease the u-joints, gimbal bearing, splines. I would like to grease with what was used before and not mix greases (if that matters) so... What color is Mercury/Quicksilver Gimbal bearing and u-joint grease? What color is the spline grease?
87Aggie
Re: 2000 Bravo 3 grease color
Thank you so much! Exactly what I was looking for. I'll remember to check the MSDS on things the next time.
BTW - you s/b able to grease the coupler and the gimbal without removing the outdrive. U-joints require removal of the drive.
