2000 Bravo Three lower unit detachment
87Aggie
Needing to separate the lower from the upper. Looks like 4 nuts below the cavitation plate and two above. Will this do it? I'm needing to have my prop shaft seals replaced and wanting to just take only the needed unit to a shop to have it done.
mr300z87
There is a 5th bolt under the anode. See part 50 in attached diagram
87Aggie
So, it's just the 5 under the cav plate (the 4 I mentioned and the one under the anode)?
Being you have a 2000 drive, there is 7 total fasteners, 3 nuts on each side and one bolt on the tail.
87Aggie
Thanks guys for the responses. AllDodge, does that illustration come from the service manual?
yes
and I own 3 B3's and one B1 and they all have the same number
87Aggie
Thanks again, I have a service manual, not sure what number it is at the moment.
