2000 Chevy Astro - Intermittant Power Windows
jay_merrill
The front windows (electric) on my Astro have developed an occasional habit of stopping, while closing. They never stop while opening, only when the glass is moving up. If I wait a few seconds, they will move up a bit more and stop again. I've never had a problem with the windows not closing eventually, but when this happens, I have to move them a bit, move again, wait again, etc.
Anyone knows what causes this? Are the motors in the process of failing?
Re: 2000 Chevy Astro - Intermittant Power Windows
Jay it's usually the motor which is actually the cheapest part. The other two items it "could be" are the switch or the Body Control Module. Motors are cheap in the aftermarket arena.
windsors03cobra
Those vehicles have had a known Chevy disease know as a bad window motor for the longest time now. Probably also slow as molasses ?
A motor is about $50 new and oh so easy to change.
rbh
When your windows go up do they **** to one edge or the other???
alignment/track issue?
jay_merrill
Nope, they don't **** - tracking seems to be fine. They just stop intermittantly. When they do this, I have to raise, wait, raise a little more, wait, etc. At other times the windows do just fine.
MTboatguy
I had this happen on my Jeep Cherokee, so went and bought a new motor, only to find out is was a loose connection in the wiring, took it off, cleaned the contacts and reinstalled, no problem since, and that was a couple of years ago..
dolluper
Lots of causes time to check it out....check connections for being CLean and tight esp grounds spray with contact spray on switch could be very usefull....look for and sniff for burning...usually leaves wet resido....couch fixing doesn't fix it yet LOL's
Fl_Richard
THis problem is motor related. The motor wears, get hot and the thermal overload trips. The thermal cools off the motor works for a while then it trips again. Forget the switches and all the other parts if it works when the van windows have not been touched - like when you've just gotten in it.
I agree it most likely is a weak motor but first spray some rubber lube on the widow rubber to help it slide and see if this helps
jay_merrill
This makes sense to me. It describes what is going on from a visual standpoint, very well.
