2000 johnson 60hp help
wilson750
Motor cranks slow. Tried 3 fresh batterys. All slow crank. Checked grounds. Will start with pull rope on flywheel. Any help to this would be great. Im on vacation with this problem
Yes it will.------Turn key to on.-----You have to use the red lever on the primer and squeeze the primer bulb once.----Return red lever to run position.--Pull the motor over.----Motor will start and run with a dead battery.
wilson750
Battery is not dead.I have stared it with rope.thinking starter went bad? Open for suggestions.
