2000 Mercruiser 5.0 pdf manual...
toddb3
I just picked up a 2000 Chapparal SSI 196 with a 5.0 Merc. Any body have a link on a manual? I want to replace all the fluids and take it out but cant wait for a manual to be delivered. Damn it I'm too excited to wait.
Thanks
HT32BSX115
Re: 2000 Mercruiser 5.0 pdf manual...
Howdy,
Well,
you really don't need a manual to change the oil and filter etc....
Just do it and take it out!
Ayuh,...... There is None for that vintage motor..... Ya gotta Buy it......
toddb3
Any suggestions on oil weight and quantity?
Every type oil in the world has been used in a boat by someone, and they all swear it's the best.
But here is what Mercruiser recommends.
Ayuh,....... You got it Don,........
Head'em Off at the Pass,................ ;) :D
toddb3
Thanks for the info, Quicksilver 25w40 it is but does anyone know how much? 5qts. 5.5qts.?
JustJason
its usually between 5 and 6... BUT...
and this is a big but...
You should put in bout 4 1/2 then float the boat and check the level while the boat is in the water.
Over full is a problem
Below the add mark is a problem.
Put oil in till you get in between the add and the full mark. Do not overfill or underfill.
