2000 Nissan/Tohatsu 8 HP squirts water out the front of lower unit. Is this right?
robertjp
I bought a used 8 HP Nissan outboard (2000 model) and I noticed when hooking up the muffs with a hose, it squirts water out the back in the normal place but also out a small hole in the front of the unit. I went online and it seems a few others also noticed this. Does anyone know if this is supposed to be there? Seems odd.
Take a look at the pics. Did I get screwed or is this suppose to be there? You would never notice unless you had the muffs hooked up. Wouldnt see it in the lake or a barrel. Thanks BP
https://youtu.be/OXzdpLN8x-8 heres the youtube vid to see squirting in action
Sea Rider
Those are water drains, when on muffs helps to release water inside leg, nothing to worry about..All Tohatsu have them in different leg heights.
Happy Boating
