2001 Mercruiser 4.3 Drain Plugs
redblur
This is the first time winterizing this boat, I don't have the owners manual and the service manual I have is no help because it says drain the water.
Are there 4 or five drain plugs on this engine? I've drained the two on the block and the two on the exhaust risers, is that it?
Re: 2001 Mercruiser 4.3 Drain Plugs
You should also Pull the Big Hose from the engines water curculating Pump,....
And, the P/Steering Cooler,... Either of the Big Hoses here too....
And,.... If it's so equipped,..... drain the Fuel Cooler......
