2001 Mercruiser 5.0 plug change
bman1bpm
It looks like the cooling hoses for the manifold/risers block the front 4 plugs. Any tips to make this easier? I'm thinking I need to remove the hoses for access.
Ayuh,..... As with everything when workin' on boats, ya gotta remove whatever's in yer way of gettin' to whatever ya wanta fix,.....
bman1bpm
Well not the answer I wanted but it is what I expected. Still saved me an hour of standing on my head with a mirror in my hand and getting in and out of the boat trying to find a combination of wrenches and sockets that would work around the obstruction.
Bt Doctur
Nope, all the plugs are accessible as is in most cases. You need to grind down a sparkplug socket and use either a 3 inch or 6 inch extention in 3/8ths drive
QBhoy
Hi
you don’t need to remove anything to get the plugs out. Just the patience of a saint and move the hoses out the way for the awkward ones. A standard medium extension on your ratchet will be all you need.
From memory, the forward most 2 plugs on the starboard side and the 2nd most forward on the port are the buggers. Persevere and you’ll get it.
