2001 opti 135
tlh 178
serial # OT274600, would like to replace popit valve. do i need to remove lower cowling or remove oil reservoir to get at popit? also have read there is a screen that can clog up on cooling lines. but for the life of me cannot find where its at. i think it hooks onto air compressor somewhere. thanks for any advice!
Re: 2001 opti 135
Poppit valve should be on base of powerhead, on the starboard side of the motor. You will need to pull 1/2 the lower cowling. I had thought the screens in the cooling system on an Opti were where it cools the compressor. Not sure though.
