2001 Yamaha VMax 200(VX200 TLTZ) Over Heat Alarm
mibowman
Greetings,
The alarm buzzer go on immediatly when the key is turned to the on side. Don't even have to start engine and the buzzer sounds. Any suggestions?
Thank you for all the help in advance!
Brian
99yam40
Re: 2001 Yamaha VMax 200(VX200 TLTZ) Over Heat Alarm
Are you sure it is overheat?
Does the tach indicate overheat or is it just alarm going off?
mibowman
The over heat buzzer and alarm light, on the left , is on. I am not sure if the motor is in over heat. Not sure - Could this be an issue with emergency shut off?
99yam40
some motors also alarm on low oil, low voltage, and water in filter, so not sure what is setting off the alarm.
If the overheat light is lighting up then I would be looking at the wiring or bad temp switches/sensors
mibowman
Thanks for the information. I chased the wires from the Thermo sensor and found an arching problem on the top of the CDI unit. Thank you again.
