I have a 2003 Mercury 200 hp Saltwater edition. It is a carbureted Motor. Can the oil pump be removed and a delete kit installed? Premix 50:1 than after. I have heard that it would not get proper oil to the crank and other parts of the motor through the Bleed system. Plus normal start up with the oiler is 100:1 then goes to 50:1 as it has more throttle. Heard that it will create carbon build up on the piston rings that could make them stick and score the cylinders. Just trying to stop an oiler break down and destroy the motor if I don't delete the oiler on a 23 year old motor.
