2004 150HP Optimax - what is this?
GAC112
I have the above motors on my boat. While working on them I found a red looking valve kind of thing - located in the front of the motor, pinched off. (smashed by the cowling) It looks as if it is connected to a 1/4" gray tube that runs to the rear of the motor and appears to connect to a tee and then connect into the block at the bottom on both sides (hard to see). I looked in the Maint manuals I have and didn't see it anywhere. Anyone know what it is? Thanks.
Fun Times
Like the one pictured below? If so, it's too connect up a water pressure gauge system.
http://forums.iboats.com/forum/engi...all-a-smartcraft-system?p=5772219#post5772219
http://www.bbcboards.net/mercury-mo...x-water-pressure-gauge-installation-help.html
dwco5051
Not familiar with that motor but as a wild guess I would say that could be the connector if the boat had a water pressure gauge.
