2004 9.9 mercury starting
tlh 178
how many time should you squeeze the primer bulb, to start a cold motor? seems like i'm always flooding her out. thanks guys and merry xmas!
The primer bulb is a manual pump.-----It is used to fill the carburetors on marine motors.----That saves the starter motor or your arms and shoulders from doing this.------The bulb must go firm after several pumps.-----If not there is something wrong or there are leaks.
ondarvr
Unless there is something wrong with the carb you should never be able to flood the motor by squeezing the bulb.
tlh 178
thanks guys, i rebuilt the carb and my kicker has never ran better. can get down to 0.7 mph for trolling. wife and i fished saginaw bay on xmas day. boxed 13 walleyes. i tried to upload the pics, but it said failed upload.
