2005 Mercruiser 5.0 MPI overheating at idle only
There is no issue on a boat open cooling system like yours, if it was closed cooling there might be an issue, but not on the raw water side.
Ming15237
Well she ran all day at 160 degrees! SHE IS FIXED!!! If i had to point my finger at one thing that caused this issue I couldn't. I guess it is possible that there was debris inside the engine that a flushed out and didn't see, but their was not that was obvious. There was a small amount of rust shale that came out of the motor but that was it. I was really concerned that a cylinder head had cracked or a head gasket had failed. Thanks again for everyone's input on this.
Glad your up and running and also for providing the follow up answer
Happy boating
