2006 Optimax 90 hp ecm failure, send ecm out for reflashing.
hall832
Send out the ecm to Simmons motor sports to flash the ecm. Any of you ever have experience with this.
wired247
Re: 2006 Optimax 90 hp ecm failure, send ecm out for reflashing.
Grab your ankles.
hall832
Please elaborate,
wired247
Reflashing through Simons is $600 last I checked. If the ECU actually failed its not likely a program fault that you could fix through reflashing the ECU's ROM.
Fun Times
What seems to be wrong with the ECM?
Try contacting Mercury or a dealer with your serial number to make sure there was no service bulletins of what seems to be wrong.
Contact Us | Mercury Marine
hall832
Wired247 thank you for the reply. I have had luck with a reflash on older Optimax.
As always fun times thank you. Will do in the in morning.
No spark. Have fuel pressure and air pressure. No codes showing up on scan.
hall832
Just an update
Got ecm back in four days. Installed, fired right up and running perfect. Simon Motorsports thank you very much.
Fun Times
Cool! Any report of what went wrong? $$$?
hall832
Eric said broken wiring inside
