2007 3.0 Carb Settings
bjarnold1
What is the factory spec for the air/fuel mix screw?. I've seen posts that say 1.5 turns out, 2 turns out, 4 turns out
Fun Times
Being a 2007 engine year the carb should be a TKS (Turn Key Start) so getting access to the air mixture screw is a bit more challenging and it takes a special fitting tool to help adjust the screw.
TKS Carburetor Mixture Adjusting Tool 91-866201​
