2011 f250uca sounds like 2 stroke
robaloroger
bought the boat with motor. motor has over 2000 hours but powerhead was replaced a few years ago. dropped lower unit and exhaust looks clean. When the motor is running it is extremely loud like a 2 stroke. Never heard a 4 stroke that sounds like this. It is definitely coming from the exhaust. No tapping, knocking or winding. Sounds like a muffler was removed from a car
robaloroger
I did a water test to see if water was coming through the dry exhaust and it wasn't.
mike_i
This may not be your problem but there were some motors that had exhaust corrosion issues. You may want to research this, it couldn't hurt.
robaloroger
I don't think that is the issue with mine. That is why I did the water test. I guess I would have to get it scoped to be 100%
