2020 25hp Mercury Water Problem
jspansel
Today I noticed that my water stream was not super strong like usual, but still steady. Then my overheat alarm went off. Shut it off, then started it up a couple more times to try and diagnose. Water was flooding the inside of the cowling. Then I saw it was coming from the side of the motor with the oil filter. There is a hole that looks like it should be plugged. I found a small metal plug looking thing in the bottom of my cowling but I cannot grab it. I assume that was press fit in there? Not sure what that is for or how I would replace. There are no threads on either piece. Water gushes out this hole. Thoughts?
Model: 1A25411KK
S/N: 1R031250
F25ELHTP
Looks to me that should be plugged. Most likely it was and the plug blew out
