21' 1972 Starcraft Holiday - Splashwell question
BOAH
I have a 1972 Holiday that has been modified quite a bit but still has the original splashwell. I have a problem where the splashwell meets the transom. I've tried sealing that with just about everything I could think of but it always ends up cracking or pulling away which in turn lets the water drain down into the bilge. Attached is the latest attempt to seal this up. Any thoughts or suggestions?IMG_0671.jpeg
MNhunter1
Are there a bunch of screws securing the spalshwell to the transom on the underside?
Not sure exactly what we’re looking at.
My splash well is glassed with scuppers thru the transom to drain the water.
Has a fold down “Starboard” door to allow the motor to be trimmed to full “trailer” position.
BOAH
Mine looks like it's been spot welded in a few places. No screws that I see. Maybe I'll try to get some better pictures so you can see it better.
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
If you splashwell is separating all the time, I would check your transom to make sure it is still good. Something is twisting during use that is causing the stress/separation to occur.
SHSU
SHSU
Yep , Im thinkin something is flexing enough to keep pulling that seam apart. 🙂
