25' pontoon engine question
Pontune
I have a 25 ft sun tracker with a 115 with 8 people in it I only get about 18 mph I'm wondering if going to a 150 will make a big difference
ahicks
What is your top rpm at wide open throttle (WOT)?
17' sounds like a lot of prop to me. I consider stainless to be bling at these performance levels. Fine if you have it, but I would never pay for a new one.
Our 90hp Honda (4 stroke) will run our fairly light 24' to 25mph on either a 13 or 15" prop.
Not in speed, however the noise level and fuel consumption would go up.
2 logs no strakes 5 adults average build & 3 kids under 10 has a 17 pitch s.s prop
you would need lifting strakes and maybe a 3rd log to get the 'toon up on plane
HotTommy
The Mercury Prop Selector tool suggests a pitch of about 13 for a standard gear case and about 14-15 for the Command Thrust gear case. It appears you have too much pitch. That can be confirmed by noting the RPM at WOT. If it is well less than specified for your engine (e.g., 5500 RPM), then you could improve performance with a different prop. .... My 24' two log pontoon boat with a Mercury 115 HP Command Thrust engine sees about 21-22 MPH with the same load you describe.
Pontune
WOT is at about 5800 rpm I have been told that putting a 150 on it would make a big difference on top speed roughly 25 mph just not sure if that is true
wahlejim
Something is not adding up here. Using gear ratios of 2.05 and 2.31, your prop slip is coming in at 55-60. Either your readings are inaccurate (not your fault, could be faulty Tach or speedometer), or you are way over propped. I am guessing a combination of the 2. I would verify readings, and try a 13 pitch prop as suggested. You should be able to see mid 20s. I would dial the prop in, much cheaper and easier than a new engine.
HotTommy
Pontune,
Google Mercury Prop Selector and check the results for yourself. If your speed is coming from a water driven speedometer, load a GPS app onto your smart phone and check it again. I suppose its possible your prop is slipping on the hub, but that usually results in a sudden high RPM with little thrust. .... I agree with wahlejim - this is not the typical wrong prop story. Something is off.
HotTommy
Pontune,
Here's another data point for your consideration. I just took my boat out in calm conditions with a very light load (just me and a half tank of gas). I hit 26.5 MPH using GPS.
