25hp Johnson outboard
Markerss225
25rl72r Johnson 25hp has melted plastic in exhaust tube? What does that mean? What do I replace? Is the gasket plastic?​
Markerss225
Part #1? There was was seam to me like plastic melting down the exhaust housing you can see between the bolts what is still stuck in there. Is that soot? Feels like plastic. Also the gasket between the engine and power head was kinda blown out. The surrounding foam/ rubber like gasket is oil soaked and bloated IMG_0764.jpeg
Part #1? There was was seam to me like plastic melting down the exhaust housing you can see between the bolts what is still stuck in there. Is that soot? Feels like plastic. Also the gasket between the engine and power head was kinda blown out. The surrounding foam/ rubber like gasket is oil soaked and bloated View attachment 409559
I just see an old gasket and exhaust build up. Assuming the GC is off, spray break cleaner in there, clean it up nice and install a new gasket.
Markerss225
You’re saying the inch of hard stuff around what I assumed was the gasket was all exhaust build up? Is it like Creosote? I have the gaskets coming in the mail as well as other parts I’ll be sure to try to clean it all out.
