2nd id hull number
Duanen
I have a 92 Astro Bass Boat that has 2 of the id hull numbers worn off. Does anyone know where the 2nd id hull number is located. Thanks
Re: 2nd id hull number
Usually they are molded or stamped into the transom visible from the outside. If you know the hull number you can re-install one. It really depends on where you are located and what your registration rules are.
As far as fining a hidden one or a second one is tricky. Not all manufacturer's did that.
Welcome to iboats
