3.0 exhst riser 1/8NPT drain plug ALUMINUM?
Tycer
Hey guys,
My aluminum drain plug has anoded away on the exhaust riser. Is it supposed to be aluminum so that it works as an anode? Or can I replace it with brass.
Ayuh,...... Never seen an aluminum one,..... Brass, Yes,....
someone probably dropped the brass one in the bilge, couldnt find it, and installed an aluminum one in its place. the motor was shipped with a brass plug.
Hey guys,
it should be brass
