- Joined
- Mar 8, 2009
- Messages
- 44,097
The issue which is unknown is the cam lobe, are we getting a full stroke for the pump?
How to test:
Disconnect power to coil.
Remove fuel pump
Measure the distance the rod moves as the motor is rotated
The pump on this engine is the lever arm type: 8M0073435 so I'm not sure how to measure the stroke, I can say that the wear area from the cam is in the right place on the lever.
Ah don't know what to say
